Configure Ethernet MSTP MSTI
Use the following procedure to configure the Ethernet MSTP MSTI parameters on a port.
Configure Ethernet MSTP MSTI:
Switch(config-if)# spanning-tree mstp msti 62 priority 32
Use the data in the following table to use the spanning-tree mstp msti <1-63> command.
Variable |
Value |
<1–63> |
Specifies the instance ID. |
cost <1–200000000> |
Configures the path cost for the port |
force-port-state enable |
Enables MSTI learning for the port. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
priority <0–240> |
Configures the priority for the port. Enter the priority value (0–240) as increments of 16. |
